Proper use of seafoam on a TPI engine
Car: 85 Trans Am
Transmission: 700-R4
Right now I have 2 pint of Seafoam and one can of Deep Creep. I was wondering what were the proper methods for using this on a TPI engine.
Will it hurt the O2 sensor?
Thank you
Thank you
Car: 90 Formula, 02 ws6
Engine: 305 tpi, ls1
Transmission: 700r4, t-56
Axle/Gears: stock posi 2.73, 12 bolt with 4.11s
it is o2 safe
pull the vacum hose off of the brake booster and pore it in per the instructions on the bottle
after you stalll it and let it sit a bit then re start it
take it out on the highway and blow out all the sh*t
easy and fun to smoke out your block
Car: 85 Trans Am
LOL
I was wanting to put this in the crankcase and fuel tank also. But I just got to thinking if I use the Deep Creep to spray into the throttle body then I should not have to put the other stuff in the Vac line. Right? Or is the DC just for cleaning the plenem/runners?
Car: 85 Trans Am
Also, When should I do an oil change after putting this stuff in the oil? Could the gunk it's cleaning out clog up my oil pump?
do not put it in the oil it will do nothing but thin the oil
and dont put it in the fuel that will cause problems just put some fuel system cleaner in
if you want put some engine flush in then change the oil
if the deep creep is a spray then take the air intake tube off and unplug the maf. start the car and spray it into the tb and rev it up and let it back down till the bottle is empty
just put the seafoam in the vac line per the instructions
Car: 85 Trans Am
What will it do I have never heard of it causing probs? So will just putting in the vac line help out alot? Last question, is the DC doing the same thing?
i never heard for DC really but if it is a spray it will clean the upper intake
the seafoam is more for the lower intake and the valves and combustion chamber
i dont know if it will really cause problems int he fuel but why not just put some fuel system cleaner in
it will work better then the seafoam thats for sure
its not ment for that
Car: 85 Trans Am
cool b/c thats the main thing I wanted to get clean. That and my pistons.
Thanks for the info.
welcome
i just used it in my car last week but i used the gm version(top engine cleaner) and i had a huge cloud of carbon
The_Phoenix
09-03-2015 10:56 PM
R3500
08-17-2015 12:16 PM
Sanjay
08-12-2015 03:41 PM
