engine grounds
Car: 1988 GTA
Engine: 355
Transmission: 700 r4
engine grounds
does anyone have a chart or diagram of where all the engine grounds are? I'm having some intermittent electrical problems and i think the grounds would be a good place to start, but i don't know where they all are.
Car: 77 El Camino
Engine: 355 Converting to TPI
Transmission: Converting to 4L60/4L60E
I looked up a 1988 Pontiac Firebird V8-350 5.7L and this is what I got:
Ground G100 (VIN F): Lower LH Front Of Engine
Ground G102: LH Rear Corner Of Engine Compartment
Ground G103 (VIN E): On Radiator Support
Ground G104: On Radiator Support, Behind RH Headlights
Ground G108: RH Front Of Dash, Above Center Of Blower Motor
Ground G112 (VIN F): Rear Of LH Cylinder Head
Ground G118 (VIN F): Rear Of RH Cylinder Head
Ground G123: RH Front Corner Of Engine Compartment
Bill
Bill
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Check the main one bolted to the motor, this has a tendancy to corrode between the block an plate over time and is usually the biggest problem in the grounding system. Don't forget the antiseize.
Car: 1988 GTA
Engine: 355
thanks a lot, so the maf grounds are on one of the cylinder heads, ill have to check those.
interesting thing though, ever since i got my car back from the tranny shop these electrical problems have been happening. im willing to bet that they knocked a couple of those grounds loose when dropping the tranny.
