l98 cam and heads
Old 07-11-2004 | 12:00 PM
GTA matt's Avatar
Car: 1990 GTA/1989 Iroc
Engine: L98/383
Transmission: 700r4/t56 magnum
Axle/Gears: 9"
l98 cam and heads
Anybody ever had trouble tuning a MAP sensor car after replacing the cam and heads? i plan on using a cam simliar to the Lt1 hot cam and GMPP fast burn heads. i heard that the MAP sensor does not recognize increased airflow after mods like a MAF does.
Old 07-11-2004 | 12:05 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Correct, you will need prom tuning to runthat combo efficiently. Start with a few searches. Tuning will require you to learn and buy a bit more also. I also think you Mean "LT4."
Old 07-11-2004 | 12:10 PM
GTA matt's Avatar
Engine: L98/383
Axle/Gears: 9"
i have a tech 1. will adjusting the fuel pressure and watching the 02 signal be enough. i checked it and at WOT i could change it from rich to lean easily by adjusting the fp. its going to be hard for me to get a custom chip, especially after spending the money for the hypertec chip
Old 07-13-2004 | 07:23 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Read the "banned topics thread" it is either at the top of the TPI board or prom board. It will tell you a lot more than I can write. Adjusting the fuel pressure as the only means of tuning is a no no. You will actually need to change your Volumetric efficiency, required fuel, pulse width, etc.
Frozer!!!
01-19-2024 04:55 PM
lt500r55
09-01-2021 01:30 PM
bamaboy0323
09-03-2015 06:07 AM
SLNTSCPE
08-22-2015 09:15 PM
anesthes
08-08-2015 09:37 PM
Quick Reply: l98 cam and heads
