High Idle after Edelbrock Install
Car: 1992 K15 Blazer
Engine: 383 with TPI, Edelbrock Intake & Runners, 24lb svo injectors, 730, $8d
I Installed a Edelbrock TPI Intake and Runners over the weekend now it idles around 2,000 RPM. Any Ideas?
By the way it is a Speed Density System.
Car: 92 Z28 Camaro
Engine: 350 TPI : Supercharged
Transmission: TH700R4
Hey MARKGYVER, I am having the very same problem after installing an Accel intake and SLP runners on my 92 Z28. Have you found your problem yet?
Im pretty sure I put my runners on the wrong side I am going to switch them tonight.
Car: 92 Z28 Camaro
Make sure they are not leaking, that was my problem. I used some Mr. Gasket gaskets, and swapped them out for SLP gaskets and they sealed it up and fixed the problem. Good luck with your car.
Fixed the problem
Turns out I had my runners switched. The Driver side needs to be the runner with the Idle Air tube blocked off
theshackle
09-17-2020 08:26 AM
86IROC112
08-17-2015 02:00 PM
