Scanner readings...okay?
Old 07-03-2004 | 01:30 PM
redrummer's Avatar
Car: '88 Trans Am GTA
Engine: 5.7L L98
Axle/Gears: 3.27 Aussie 9 Bolt
Code 33 - MAF reading too high
Knock Retard = 0
IAC = 159 steps
Injector Pulse = 4.2 ms
Desired Idle = 862 rpm
Run Time = 88 secs
Engine Load = 116
Throttle Sensor = .49 volts
MAP sensor = 1.54 volts
Engine RPM = 702
MAF = 17gr/sec
EGR Duty Cycle = 0%
CCP Duty Cycle = 0%
O2 Sensor = 512 mv
O2 Cross Counts = 1
Fuel Pump = 11.2 volts
Block Learn = 128
Rich / Lean = Lean (had cold start switch on)
Spark Advance = 18.2 degrees
BLK LRN Cell = 4
Open Loop
Knock Sensor = 120
Integrator = 128
whtltng89
09-08-2015 07:06 PM
Electro_X
08-19-2015 07:59 AM
mizz0313
08-12-2015 06:45 AM
bowtie1983ss
12-04-2001 12:18 AM
Mark305TBI
01-28-2001 11:20 PM
Quick Reply: Scanner readings...okay?
