maf question 88 LB9 305 tpi
Old 06-27-2004 | 08:05 PM
markus9's Avatar
i'am new to using a scan tool and making some progress, my question is when i start my car cold the maf reads about 1.75 volts , as it slowly warms i notice the maf voltage slowly starts to rise up to about 2.6 to 2.7 volts is this ok !
Old 06-29-2004 | 10:59 PM
DON 88T/A's Avatar
Yes...the wire in the maf is heated to a certain temp,and as air passes it by it ,it is cooled ,thus the ecm ups the voltage to the maf to mantain the temp on the wire,and uses this voltage to calculte the air to fuel ratio..
Old 06-30-2004 | 02:20 PM
markus9's Avatar
thank you don for the info!
BlueIroc-Z
06-09-2019 03:22 AM
drewdock87
South Central
08-18-2015 09:02 PM
st.evel07
08-13-2015 06:15 PM
Sanjay
08-12-2015 03:41 PM
drathaar907
08-06-2015 04:20 PM
Quick Reply: maf question 88 LB9 305 tpi
