which bolts to use for runners have diagram
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
Transmission: T-56 fully built WOOHOO
ok where all the dots go i want to know which of the hex bolts to use as i have ones that are longer just re save it or something whiche ones do i use for the longest bolts... not the shot ones i believe the name on the bolt is c bolt
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Your long bolts will go down on the runner to intake. Look for the area's that have the thickest area. There should be two medium bolts that go one at the front of the right runner and one at the rear of the left runner from the inside of the manifold. The center bolt on the left side of the plenum should be an 11MM bolt with a nipple on it.
toronto formula
09-10-2015 07:31 AM
MikkoV
09-09-2015 04:25 PM
UltRoadWarrior9
09-02-2015 08:24 PM
