Stealth ram help!
Car: 1992
Engine: 350TPI
Stealth ram help!
Well I put in my Stealth Ram. I got just everything except the commander unit. Got a good deal at a weekend car show/swap. The car will run but won't idle below 1500 RPM. Around 5000 I get a thick black cloud of smoke at WOT. Holley tech said I had to buy commander but read on the boards that the stock ECM would work. Help. What do I need to do to tune this ram?? Engine specs in my sig.
Thanks!!
Thanks!!
i would say check out the computer board and see who they all recommed to tune the stock computer. then contact them and get ur ECU tuned asap. i think that that might solve ur problem. but i'm not positive. all i know is the ecu should def be tuned for ur mods and stealth ram.
Car: 87 Trans Am GTA
Engine: 408 LS
Transmission: LS 4L60E
Axle/Gears: 9 Bolt/3.70 Gears/TAP Girdle
you'll definitely need to get a chip tuned for that car. check out www.stealthram.com for more info to
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
Sounds like you have to adjust the TPS/IAC some and you will need a computer chip or you'll have to turn your fuel pressure up so high you are pig rich at idle/cruise to make acceleration and wot "livable"
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
you have other issues. i had my 383 running on a completely stock 87 ecm and chip. sounds like one or more injectors stuck open. or major vacuum leak. my thought would be the intake gasket slipped. or plenum gaskets didn't seal. another thought would be the MAP sensor. is it plugged in? vacuum line hooked to it?
When I put my stealthram on my 355 with pro heads and comp xe262 cam, it would run with the stock ecm/chip... but had no pumpshot and I got a horrible lean pop and WOT was horribly lean also.
I had to crank the fuel pressure to about 54 PSI to get it happy but it made idle and cruise pig rich.
Cam has alot to do with how it is going to run with the stock calibration.
Are you using any oil? If not you might be able to rule out an internal vacuum leak. WOT black smoke means too much fuel. What is your fuel pressure set at? How is your ignition system?
Car: 1992
Engine: 350TPI
I barrowed a fuel pressure guage and it was readed 59 PSI at idle. I drove around with it hooked up and around 5000 RPM it shot up to 83 PSI. I am going to try to get a new regulator. Perhaps the one that came with the ram was messed up.
As far as I can tell everything is hooked up right. I dont think its a gasket problem.
Engine: 360 HSR
did you get the adjustable regulator? if so, the screw the vacuum line attaches to is the adjustment. get it down to 45 psi with vacuum line off. don't forget to sign up over at www.stealthram.com
Car: Sexy
Engine: Stock
Transmission: Slipping
Make sure your throttle cable isn't hitting the fuel rail on the driver's side. That could explain the high idle.
Car: 1992
Engine: 350TPI
I got a Holley regulator but havent put it on yet. I noticed a puddle of gas on the engine. I took my hood off and tried to see if I could see anything while driving and ended up having my girlfriend sit in the engine compartment. My girlfriend was watching the injectors as I drove around and says the back 2 spray gas out above 4000 RPM at WOT to the sides.
Engine: 360 HSR
Originally posted by Zerstörer
I I took my hood off and tried to see if I could see anything while driving and ended up having my girlfriend sit in the engine compartment. My girlfriend was watching the injectors as I drove around and says the back 2 spray gas out above 4000 RPM at WOT to the sides.
Car: 1992
Engine: 350TPI
Originally posted by mrr23
and she did this WILLINGLY?
I would like to replace those 2 injectors. Do they have to be a specific brand? They look like stock ones to me but are they rated higher for the ram? Can I reuse the factory TPI ones I have instead of the ones that I got with my ram?
Car: 1992
Engine: 350TPI
you can use any injectors you want. i used accel 24# in mine.
Thanks!!
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Originally posted by CaptPicardsZ28
4000rpm at WOT. Was it in gear at the time cuz thats one hell of a ride!!! Sounds like o-rings to me. Make sure you lube them when you put the new injectors in.
Car: 1992
Engine: 350TPI
If there is fuel coming out of the injector bung or fuel rail that means the O-Rings on the injector aren't sealing, not that the injector is bad.
Replace the o-rings and use vasoline on the o rings and they will slide right in without tearing.
BTW you can't just put another injector in, they need to be the same brand/style/ lb per hour rating or it wont fuel like the other 6.
You don't put a big jet on the left and small jet on the right in the secondaries of a carburator!
Originally posted by Dr G
Picard, what should you lube the o-rings with when fitting new injectors?
Car: 1992
Engine: 350TPI
I put in all 8 of my old injectors and the new regulator. Runs much better now and no gas leaks, but seems to be kind of a black smoke cloud at WOT. I think the injectors I got with the ram might have been clogged, maybe thats why I picked it up so cheap at the swap. Got a mean lope at idle.
