Fuel delivery problem.
Old 06-20-2004 | 10:49 PM
89406Iroc's Avatar
I am running a 89' Camaro w/ 408,AFR heads, TPIS Miniram, 236/242 cam. etc. The problem I am having is that I will set Fuel pressure with vacuum disconnected. Set pressure to 45psi, when I do a pull driving Fuel pressure drops to 42psi. Check pressure at idle still at 45psi. Turn pressure up to 54psi at idle, do a run and drops to 50psi @ WOT with vacuum still disconnected. I figured that if I was loosing volume that I would loose more pressure at the higher FP.
What I have Tried, that has resulted in no change:
Disconnect return to check restriction. ( ran ext line for return)
Replaced Fuel pump from 255lph, to another walbro 255lph.
Changed Filter, installed T-rex inline , Checked Pressure before the rails.
Any Ideas? I am looking into an Aeromotive kit then doing sumped tank. But I figured that 255lph would handle it.
Thanks, Chad
92camaroJoe
07-29-2023 07:57 PM
Grant2k
07-10-2018 04:01 PM
Infested
05-22-2018 11:56 PM
92camaroJoe
08-13-2015 06:07 AM
Quick Reply: Fuel delivery problem.
