Car Running Rich
Car: 1986 Pontiac Trans Am
Engine: 5.0 TPI
Car Running Rich
....305 TPI...mods listed below. Need some opinons...has a major problem starting unless i press the gas pedal down...it cranks for 15+ seconds....when it does fire, the idle isnt too great, has a hard time having a "healthy" idle for a good 20-30 seconds. When i'm driving and stopped somewhere(light, stop sign), idle isnt smooth, car shakes. No codes/no check engine light. Has stalled out a few times after a long trip. I know it runs rich b/c of the smell comming from the exhaust, and also my stainless tips are black around the lips. Last summer/fall i installed the Accel stuff, and also all new relays related to the MAFS, a new MAFS, computer, updated factory PROM and a new Idle Air Control Valve.
So what could cuase this now? Thanks.
Engine: 5.0 TPI
Re: running
Originally posted by robsgta
Make sure that your TPS sensor is set correctly.(throttle position sensor).
Engine: 5.0 TPI
Originally posted by Denis.V
What about the injectors?. How old are they?. Mileage?, Age?.
Denis V.
Denis V.
