AFR/LPE219/SR driveability?
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
I couldn't really find anything on the driveability of an AFR, LPE219, SuperRam combo, can anyone chime in? City/highway mileage numbers would be helpful also. Most consider me VERY picky, I hated my 355 with a hotcam, HSR and vig2800, poor street powerband and bad mileage.
1 Post
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Do some searching(at least more) Cant remember the name ?Buckeyeroc?(not sure) ran i think the same or very simliar combo and was entting bottom 12's and happy with streetability
i know one or two other folks here runnign somethign very close to that as well
later
Jeremy
later
Jeremy
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
The combination works very well on the street. Mine idles steady at 800 RPM will get high 20's for mileage on the highway and low 20's all around, runs in the 12's for the 1/4 ET's.
The low end power is good it will cruise fine at 1400 RPM at 60 MPH.
High 20s on the highway if definately what I want to hear, barely broke 20mpg with my old combo. bjankuski, what size runners do your etec's have?
Car: 87 Trans Am GTA
Engine: 408 LS
Transmission: LS 4L60E
Axle/Gears: 9 Bolt/3.70 Gears/TAP Girdle
are you going to run an auto or a 6 speed like bjankuski? numbers could be different with an auto tranny
Originally posted by PLANT PROTECTION
I plan on going T-56 and want to put this engine combo in a 2600lb 240z.
Car: 92 Z28
Engine: 357 TPI (L98)
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
I was very happy with the streetability of the AFR 190/LPE 219/SR combo. That's actually part of the reason I sold the car, I want something faster/more radical.
I used the ARAP.bin w/ a few changes for the 24# injectors, and idle speed, etc, but never did tune the car. It still ran excellent on the street. 12.1's full weight with drag radials. EXCELLENT street powerband, instant power at any rpm. Do a search under my name and check out the dyno it ran. No idea on mpg #'s, car was going to be my driver but ended up a weekend car. Never measured mpg.
I know I will love the performance of the combo, and it sounds like the driveability is right up my alley. Now all I gotta decide is AFR 195s or TPiS AFRs.
1 Post
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I have the same combo with TF Heads and LS1 Injectors. Like others said, idles smooth, good MPG and instant power. I'm using an S-10 converter with no problems.
