89 MASS Air meter
Car: 88 IROC-Z, 01 10th Firehawk M6
Engine: 355 TPI/425 HP
Transmission: Vette 700-R4
Axle/Gears: 3:73
89 MASS Air meter
I heard that a good HP gain can be attained from swapping in an 89 MASS with no prom burning, just plug in and go.
Anyone else hear this?
Mine is an 88 so I wonder if the factory hp diff would be programmed into the 89 meter?
Car: 1989 Iroc-Z
Engine: 5.7L TPI
If you are referring to the Mass Air Flow Sensor (MAF), I do believe that the part is the same for both years and would not make any difference.
Axle/Gears: 3:73
Thats what I'm referring to (MAF) but I just heard that they were different and could provide a benefit, so I thought I'd ask, but you might be right, they may be the same part #.
I'll check at work tomorrow.
Car: 1989 Iroc-Z
Engine: 5.7L TPI
You may be thinking about the Manifold Absolute Pressure (MAP) sensor which is not compatable with the 88 or 89 TPI engines without some major modifications.
Axle/Gears: 3:73
okay thanks,
Any ideas of getting a bigger MAF like the 4th gens or a MAF translater like the Buicks can now do.
Mine already has the screens removed.
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Same part. '89 did not have a cold start injector. You are probably hearing about the Wells unit. No we can't use the newer MAFs yet. No we don't have a translator. Unless you are making serious power, you really don't need to remove the screens.
