? about high torque starters......
Car: 89 IROC
Engine: 350 HSR
Transmission: modified 700R4
can they get heat soaked like stock starters?I was informed that they can't so I installed one a few months ago.Didn't have a problem until it got warmer the past few weeks.After driving then letting it sit it doesn't start till it's cooled down acting just like a heat soaked starter.
BD3
BD3
Car: 1988 Monte SS
Engine: ZZ4-cammed TPI 355
Transmission: World-Class T5
I haven't had any problems with my Summit mini-starter on my TPI 305, but I also run a home-made metal shield. It's bolted to the bottom of the starter and goes up between the header and starter motor.
Check to see if your connections are tight, especially for the solenoid.
Ragtop Man
09-12-2015 12:23 AM
