Vortec heads/TPI combo
Old 06-11-2004 | 12:29 AM
PAFORM350's Avatar
Car: 1992 Formula 350
Engine: 5.7 L98
I just finished my car. 1988 Formula 350 with upgraded Vortec heads, SDPC TPI base, Comp Cams 220/230 cam 114 LSA, 1.6 roller rockers, 58 MM TB, SLP runners, SLP 1-3/4 headers and cat back exhaust. MSD ignition and wires, underdrive pulleys, Dana 44 with 4.09 gears, 2000 stall convertor, no cat or air pump and other little things. My question is what do you think this will run?
Previously with runners, ignition, gears, pulleys, and convertor, I ran a 13.63@99 mph with a 1.99 60 foot. I guess I am just looking for a little feedback before I take it to the track. Thanks for the input.
Attached Thumbnails Vortec heads/TPI combo-tpi.jpg
Old 06-11-2004 | 08:49 AM
poncho@home's Avatar
Car: 2004 BMW 330Cic
Engine: 3.0
Transmission: 6 speed
when are you planning on taking it to the track?
For reference I run mid 13s at 101+ mph with a best of 13.34@103
See sig for details on car
Old 06-11-2004 | 05:09 PM
sillyiroc's Avatar
Car: 89 Iroc
Engine: 350 vortec TPI
Transmission: 95 T56
My combo is like yours its in my sig.
Old 06-11-2004 | 07:52 PM
Engine: 3.0
what cam are you running?
Old 06-11-2004 | 11:05 PM
PAFORM350's Avatar
Engine: 5.7 L98
Comp Cams 276H-R14
220/230 .510/.510 114LSA
Old 06-14-2004 | 12:51 AM
PAFORM350's Avatar
Engine: 5.7 L98
this has over 150 views and 4 replies? Does anybody else have any input?
Old 06-14-2004 | 07:07 PM
OMINOUS_87's Avatar
I like it.
Old 06-16-2004 | 01:39 PM
VetNutJim's Avatar
Car: Different One Every Day
Engine: LS1,LS6,L98,L83
Transmission: 700R4, 4060E,Turbo 350, Turbo 400
Here's some feedback.
It looks like..............................................FANTASTIC!!!
Absolutely bee-u-tiful.
Old 06-16-2004 | 01:42 PM
Engine: 3.0
Actually I was asking Sillyiroc what cam he has.....so Sillyiroc what cam are u running?
Old 06-16-2004 | 03:27 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Check my sig.
Old 06-16-2004 | 03:38 PM
sillyiroc's Avatar
Car: 89 Iroc
Im running the comp cams XR269hr-12. I am very happy with it so far.
Linson
09-25-2021 07:55 PM
InfernalVortex
04-20-2021 11:31 AM
69GTOby
04-18-2016 02:34 PM
Quzyle
10-15-2015 03:35 PM
monte87cortez
09-26-2015 08:10 PM
Quick Reply: Vortec heads/TPI combo
