stock injector size?
Car: '88 Trans Am GTA
Engine: 5.7L L98
Axle/Gears: 3.27 Aussie 9 Bolt
What do stock TPI injectors flow? 19lb/hr?
Would it be beneficial to go ahead and buy a new set of 24lb/hr's with my current setup?
My setup
My setup
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: stock injector size?
My setup
My setup
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
The 350 stockers are 22 lbs/hr. I think you should be fine with 22's unless your pulling a lot of RPM's.
Engine: 5.7L L98
I think I'm going to go ahead with the 24's.
I'm figuring somewhere in the neighborhood of $100 plus shipping both ways plus packaging just to have them cleaned. I estimate about $150. Brand new Accel 24's are only $230 from Summit.
I think I'll keep these stock ones for cleaning at a later date to put on the other motor I'm building.
Into this myself. Note the Accel web site calls for the 21# injectors for Camaro L98, but 24# for the Vettes with same engine. Figure the better exhaust in the Vette makes for the higher flow. My 85 Vette had lower fuel pressure than the 88 Camaro too. I'm figuring the Accel 150823 set for mine, 23# injectors. With minor mods these should dial right in. Hard to believe these things are so expensive, but I suppose Bosch gets a royalty from each one.
toronto formula
11-10-2015 06:17 AM
knight72
08-10-2015 09:32 PM
