Fuel injectors, what do you recommend?
Old 06-07-2004 | 06:28 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Been fighting these injectors for a year or so now, time to replace I guess. Seems like the Accel are about the only choice for reasonable money, but they only list a 21 and 23 lb injector, at least in the Jegs book. What should I go with? (Basic stock L98 with K&N filters, air foil, super turbo exhaust.) Factory injectors are 22 lb? Any suggestions?
Old 06-07-2004 | 07:43 PM
Half-FastRacing's Avatar
Car: 89 IROC-Z
Engine: L98 - Stock
Tom - I purchased the 23lb/hr injectors from Accel. Stock L98 and it runs extremely smooth. Not sure if the computer has to lean it out because of the higher flowing injectors. If so, it's doing a good job.
Old 06-08-2004 | 01:10 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Thanks for the response, nice to hear from someone who's actually used these. I'm probably going to get the 23# injectors, note the Accel web site calls for 24# inj. for the L98 Vettes, so the 23# should be just about right. Thanks again. tom
Old 06-08-2004 | 04:35 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Tom,
I also purchased Accel 24# injectors for my stock L98.
It has been about 3 years now since I installed them and (knock on wood ) no problems.
Best of Luck.
Old 06-08-2004 | 05:09 PM
TB_91_GTA's Avatar
Tom,
FWIW, SLP has some "while supplies last" 25# injectors for $99.00 (set of 8). Their site says they are LS1/LT1 & SVO compatible. I just ordered a set on saturday for my supercharged L98.
Old 07-09-2004 | 05:57 PM
DJXero's Avatar
Car: 1992 Camaro Z28
Are the standard 19 lb ones good for just a normal daily driver application? I'm not looking for any sort of performance injectors that would require a Prom burn, and Summit has a set of 8 for 230 bux. Are there better deals out there?
bryan623
03-22-2021 06:43 PM
sweet_87_iroc
09-25-2015 10:01 PM
gta90
09-15-2015 04:00 PM
kyleb24
08-15-2015 08:24 AM
Firechicken86
08-12-2015 10:07 PM
Quick Reply: Fuel injectors, what do you recommend?
