Energizer cam & TPI
Car: 1982 Z28
Transmission: 5-speed
Energizer cam & TPI
I know that all of yall have been asked this many times but I'm new to the TPI Stuff so here goes. 4 bolt main 350 flat top pistons 76cc heads z28 valve springs 1.94/1.60 valves. all going in a 82 Z28, The cam i picked out is a crane energizer. Jegs part #
270-100072. ADV.duration 284, Gross lift .480 rpm range is 3-6000. I plan to go no higher than 6000, 5500 rpm @ the most. My question is will the cam i have picked out work with a 1987 305 TPI setup. (have donor car) If it will then I'll attempt to run TPI if it won't work I'm going to run probably a 650 dbl. pumper or a 750 vacuum secondaries Holley. Thank yall,
William
William
ambainb
04-25-2016 09:21 PM
Sanjay
08-12-2015 03:41 PM
