Which injectors?
Car: 91 z28
Transmission: 700 R4
Which injectors?
I have searched all over this board and have read that ford injectors are supposed to be good. However, I don't want to get 24# injectors because all I have on my 91 TPI 350 are headers, exhaust, AFPR, gutted air box and TPIS air filters. I would like to get 22# injectors, because some of mine are starting to go, but there doesn't seem to be many choices. I found these two types which are reasonably priced and was wondering which would be the better choice.
TPI Bosch/Ford - 22lb
New-motor Take-outs
Bosch 0280150561 D9B-22lb
New-motor Take-outs
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
unless you plan on more big mods in the future stick with stock size injectors. if you use bigger injectors you will need a custom chip burnt.
Car: 91 z28
I know to stick with stock size injectors, I thought they were 22# for the 350 is that right. I am just wondering which of these two does anyone have experience with and which is "better". I was thinking about going with ford 24# and having a custom chip burnt by fastchip, but would rather wait until I do some more mods (cylinder heads, cam, intake, runners).
Be careful with Ford and GM flow ratings. They rate them differently. Ford 22# injectors actually flow more than GM 22# injectors which might be why you've heard that Ford injectors are "better". Get GM 22# injectors for your setup. Smaller injectors and higher pressure equals better fuel atomization and more efficient burning. For all intensive purposes you have a stock motor and have no need for extra fuel.
After re-reading the post if you can afford any down time on your car just pull your injectors, send them to get flow matched, and re-install them with new O-rings. That should cover your problems.
thejimsterz28
09-15-2015 04:37 PM
