383 guys, need header help!!!!!!!
Old 05-31-2004 | 08:28 PM
speed88's Avatar
Car: 1988 Trans Am GTA
Engine: 383
What are you using for headers????
Here is my problem. We were mocking everything up on the engine stand this past weekend and when we put the headers on we realized that the driver side header collector points right at my basepan. My basepan is a 6qt Moroso unit, so yes it is bigger than stock. My headers are Edelbrock shorties with a y-pipe designed for a single cat car. Well with the sharpe bend on the driver's header the y-pipe is not going to reach/clear around the basepan and connect to the header. And I really don't want to end up not using these headers.....
PLEASE HELP!!!!
Old 05-31-2004 | 11:07 PM
robsgta's Avatar
Car: 88GTAnotchbac/91 -Z/66 Chevelle
Engine: All strokers
Transmission: Pro built 700r4's
headers
I have the slp 1 3/4's on mine slid them in when I dropped my motor in no problems.
If you Must use your headers use your original oil pan and use a quart larger oil filter.
Old 06-01-2004 | 02:04 AM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
I've got Hedman ceramic coated shorties. So are you using a deep sump or a T pan? I'm assuming it's a T-pan, in that case you probably will have to get a custom Y-Pipe or get someone to modify your pan.
Old 06-01-2004 | 09:28 AM
speed88's Avatar
Engine: 383
I am using a deep sump pan.
Nervous2
LSX and LTX Parts
03-10-2016 09:49 PM
Reddeath210
10-06-2015 08:20 AM
Street Lethal
08-14-2015 08:25 PM
sreZ28
08-14-2015 07:48 PM
85Iroc-Z
08-13-2015 01:58 AM
Quick Reply: 383 guys, need header help!!!!!!!
