350 tpi hesitates through acceleration
Car: 1987 trans am gta
Engine: 350 tpi
I have a 87 gta 350 that has been sitting for two years. I have replaced the plugs, wires, air filter, and old gas. it will idle ok but when i put it into drive and press on the accelerator the engine bogs down and surges. if i apply the accelerator very very slowly it will slowly go pick up speed. once i have it going about 50 mph the problem is not as bad but if i press it to the floor it will bog again.
i havent checked the vacuum lines yet and i dont know where to go after that.
Location: Latrobe, Pa. about 40 miles east of Pittsburgh
Car: 87 Z28 and 71 SS/RS
Engine: 5.7 TPI
Transmission: Th 700-R4 and Warner 4 speed
You didn't say you replaced the fuel filter. Try that. It could be plugged. When you increase the throttle you put a demand on fuel and it can't force enough through the filter to feed the motor
Car: 70 formula 455 88GTA
Engine: 455 & 350 tpi
Transmission: th400 th700r4
I have a 88 which sat for 3 years. The fuel rail and regulator were pluged with white fuel deposits.
I cleaned everything and the car still ran slugish and poped and backfired. also the O2 sensor read dead lean. I instaled a set of LS1 injectors and the car runs awesome and went right thru E check.
Engine: 350 tpi
i just replaced the fuel filter today and the problem still persists. ill try the injectors next, thanks for the advice guys.
1 Post
Car: 1989 Trans AM GTA
Engine: 5.7 TPI - Stock
Try replacing your coolant temperature sensor. Your symptoms are very similar to my 1989 GTA. It would backfire and bogs down. Its ony $12 at Autozone and worth looking into.
