injector resistance
Car: 89 GTA
Axle/Gears: Borg&Warner 3.27
injector resistance
Hey guys, just brought home an 89 GTA. The usual issues with the hatch pull down motor, coolant fans and rough idle. Im in the process of checking the injectors and the Haynes manual I have specs 11.0 - 14.0 ohms and I'm getting 17.9 -18.1 on all 8 of them. They couldn't all be bad and this close could they? I'm wondering if the manual is incorrect. Awsome site btw. Thanks.
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Your injectors are all good if the resistance is that high. According to the Gm service manual, you should have a minimum of 10 OHM's or more at each injector.
Car: 1992 Camaro Z28
I bought an injector to replace an old one, and it's running at a lower resitance than the rest of mine (all others are around 18 and the new one is close to 17). is this a bad thing? Would it cause missing and poor running? How do you fix something like that???
thejimsterz28
09-15-2015 04:37 PM
