how much would my car gain from comp chip and 160* thermo?
Old 05-25-2004 | 07:39 PM
V6camaroman's Avatar
i currently had to change ym computer in my maro and the one i replaced it with i have not put back up under the dash yet. its just hanging there. i thought i could put a chip in it before i bolt it back up in there. i was looking at the selection of them and the best ive found is the hypertech thermomaster chip. its the better chip out of the two that hypertech makes. its only $121 at summit. the 160* thermostat is only $10 too. how much would i gain from the chip and thermostat in my camaro (its in sig).
Old 05-25-2004 | 08:30 PM
mjustdie's Avatar
Car: 86 IROC, 04 Ram, 05 SRT-4, 95 CBR
Engine: LB9, 5.7 Hemi, 2.4 turbo, 600cc
Transmission: 700-R4
Axle/Gears: 26 spline 3.42's for now
screw getting hyperthech, get a custom chip burned
Old 05-25-2004 | 09:35 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Don't do it, I actually lost 2 tenths in the 1/8th mile because of my hypertech chip!!! Spend the $120 on something proven!!
LB9GTA
Old 05-26-2004 | 08:57 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
......ZERO...... And your wallet will be lighter so you will be faster.
Old 05-26-2004 | 09:59 AM
White91GTA's Avatar
Car: 1991 Trans AM GTA
Engine: 5.7L TPI
Leave the Hypercrap alone...there are several people that do custom burns that will gain you more than the Hypercrap
Old 05-26-2004 | 07:57 PM
wow i had no idea that hypertech was so bad. i guess for now ill just bolt the computer back up in with the stock chip. what about the 160* thermostat though. is the hypertech thermostat any good?
Old 05-26-2004 | 08:43 PM
how much of a hp and 1/4mi gain will i see by putting a hypertech 160* thermostat, a slp tb airfoil, a asp crank pulley, lakewood lca and spohn lca relocation brackets on my car? will these mods and the ones i already have (in sig) get me into the 14's?
Old 05-26-2004 | 08:50 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
I say screw hypertech and screw burning a custom chip. Get a Prominator Pro Chip and download any Bin for a chip in Seconds. You can also download a bin or customize it on the fly. Look in the DIY Prom section. As far as the 160 stat. almost nothing
Old 05-26-2004 | 10:27 PM
White91GTA's Avatar
Engine: 5.7L TPI
Where do you get the Prominator Pro Chip at?
Old 05-27-2004 | 07:05 AM
DJP87Z28's Avatar
Its not a plug and go chip. Read about it on www.moates.net
Exxon Limited
Camaros Wanted
22
12-21-2015 10:36 PM
NBrehm
08-25-2015 11:49 PM
Poncho92
Group Purchases
08-25-2015 02:17 PM
Exxon Limited
08-09-2015 08:13 PM
Poncho92
08-07-2015 08:15 PM
Quick Reply: how much would my car gain from comp chip and 160* thermo?
