horsepower gains
Car: 89 Formula
Transmission: manual
horsepower gains
I just rebuilt my TPI 305 in my 89 Formula. I polished and ported the stock heads,installed Crane's powermax 2030 roller cam,roller rockers, Edelbrock shorty headers,160 Thermostat,Hypertech chip,Hurst Billet plus shifter,MSD 6A box,and ported the plenum. I already had modified the airbox,MAF,and installed an air foil. The fuel pressure has been set to 50 with the adjustable reg. Everything else (roller lifters,pushrods etc.)are brand new. The option or build sheet from Pontiac says the engine has 255HP@4400 295lb@3200 stock. What kind of increase should I expect??
Car: 86 z28
Engine: 355 TPI W/305 HEADS
Axle/Gears: 3/73's
WELL, lets see you've seem to have done some homework on your parts...not a bad selection. you must have spent like $1500.00 in parts, but mathmatically speaking you probably gained 50 to 60 hp.. Alittle question for you though WHYdid you rebuild a 305 and not a 350 theres no substitution for displacement....we'll good luck , hope you don't get eaten by any stangs or 55 chevy's.....
Car: 2000 Trans Am and a 85 Iroc-Z
Engine: The Mighty LS1& 305 just beat meTPI
Transmission: 4L60E and 700R4
The 305 did not have those numbers thats the 350 are they not?
The 305 made 220hp or 230hp. It made decent horse power but not no 255hp I belive thats the Vette L98 motor that made those numbers.
Yeah those mods will help a lot. I am sure you'll see about 60hp. Good luck I know we need it seeing to a how we both have 305 TPI motors. Hey Preston Smith ran a 9 second 1/4 in his 85 Iroc-Z with the 305 and a turbo. So theres hope for us.
Car: 89 Formula
just to be sure i checked again, LB9 5.0 mk6 manual trans 3:42 axle 255@4400 295@3200 the L98 with Md8 auto 240@4400 340ftlb @2800 3:23 axle. This build sheet is listed for Firebird only. Everybody says the same as you but I have the sheet to prove it. Believe me I often use it. Thanx for the reply I appreciate it. P.S. any thoughts on fuel pressure?? 50 psi OK??
Car: 87' IROC
Frst off, i would think 50 would be a little high but to really tell you need to get it on a dyno, or get into chip burning and diagnostics. Second the 305 did not have that much power. The 350 of the year was only 235hp or so. You may have a sheet saying otherwise but it is wrong. Can you post a picture of this document?
JP
JP
Car: 89 Formula
horsepower gains
I tried to post it but there is too many bytes. However give me an E-mail address and I will send it to you. By the way where did you get you specs from??
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
Just resize it, or change it to a jpeg
Engine: L98 & 355ci
Here is what it looks like for 89.
1. 305 your talking about
2. 350 Single cat
3. 350 Dual cat
2. 350 Single cat
3. 350 Dual cat
Axle/Gears: 9-bolt/3.45
Oh geez, another "why didn't you drop in a 350" guy. What's the matter? Not talented enough to build your 305? Just playing with ya, lol.
And there are plenty of 'stangs out there that can handle a 350. But at least, if we lose to one, we've got nothing to feel embarrassed about.
Sounds nice johnny. If you ever dyno it, let us know what you've got there. But I too have always thought those numbers were for the 350. But you're not the first to report having this info for the 305, so it's obviously published somewhere. I'd also like to see it posted.
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
Car: 89 Formula
that's too bad because the first pic is the envelope it came in and the return address is Pontiac headquarters in Michigan. It doesn't get any closer than that.
It came from Pontiac? Now I'm really curious.
You said it was too big to attach here? Rescan it. When you do that, you can change the format and the size before you resave it.
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
i'd like to see that as well, because the 85 ta's had the most powerfull 305's (at least for autos anyways), so if 89 has more, then my 85 has more....
if ya can't scan it, can you fax it?
Engine: L98 & 355ci
Location: Tomball Texas, right outside (north) of Houston
Car: 1990 GTA and 83,99,02 Trans Am WS6
Engine: 350 TPI,CrossFire 305 and LS1
Transmission: 4L60 and 700R4 and 4L60E
Axle/Gears: 90-3.23,83-3.42,99-3.73,02-3.42
Those horsepower numbers are wrong the 305 never had 255HP the torque is right it must be a typo the turbo T/A had 250HP the 305 would not have more than that ever or the 350 with 240HP
Car: 89 Formula
horsepower gains
it was supposed to according to Hot Rod magazine. Same exact powertrain in a Z28 pulled 14.7@93 mph
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
My book shows '89 TPI 305 as 190 HP for Auto, 215 HP for Manual trans. (Firebird Redbook from Motorbooks international) I have no idea if this is accurate?!?
Troy
So Cal
Troy
So Cal
Car: 89 Formula
horsepower gains
ya know what? You can all think what you want but so far no-one has any documentation frm the manufacturer. to prove otherwise. So if you say I'm wrong PROVE IT!!
Re: horsepower gains
We're (myself in particular) not trying to cause an argument, but these HP/TQ numbers have been thorougly covered on this board. I can see a 5-10hp +/- on certain cars, but that tech data is pretty damn close.
Prove to US otherwise. Run your stock 305 on a dyno and prove that its got that kind of HP. Run it down the track and prove its capable of consistent 14's in bone stock form as claimed by the shows/magazines you've seen.
Engine: L98 & 355ci
If the 305 has that much HP, how much does the 350 have?
Doesnt the LT1 have 275hp? You know L98s arent out doing LT1s
Car: 1988 Trans Am GTA
Engine: 383
A 305 TPI car DID NOT make 255hp from the factory. Plain and simple.
It is a proven fact on many respected thirdgen and GM websites that the fastest TPI cars from the factory in a thirdgen f-body shell were the L98 powered '91-'92's. There cars were rated at 245 hp. So how is it possible for a earlier year 305 to be making more??
You ask us to prove it?? Just look at all the documentation, and threads on this and other respected websites. I say why don't you prove to US that you have this documentation. Then I'll shut up!
There is nothing to prove except that you have a paper that has typos on it, it is common knowledge that the 305's did not make that much power I say again the 305 in 89 would not make more power than the:hail:turbo T/A:hail: or the 350 from the factory, if so then you must have one of the rarest thirdgens ever created, a one of a kind.
pmpn
the reason why the 305 has 10 less than the 350 is because the tpi is no good for a 350 . the 350 tpi has more tourque , so off the line the 350 would win
to mention about modding a 305 tpi , well i just did and took it for a ride today , still not tuned properly , i was in a race with some young punk drivinf a chrysler 300 m looks like a 2002 at least , well he got left behind pretty good ,
what i;m saying is the reason why there was not much hp difference between the 305 and 350 was because the 350 tpi;s cannot breath ,and it was designed for a 305
hope nthis helps
hope nthis helps
OK I have the dealer catalog for 1989 Pontiacs. I picked one up when I bought my then brand spanking new 1989 GTA. Here are the high specs for the engines. This is from a Pontiac factory brochure from 1989.
5.0L...225HP and 295 lbs-ft of torque. Formula and GTA only.
5.7L...235HP and 330 lbs-ft of torque.
Hope this helps. Allen
Car: 89 Formula
horsepower gains
Actually I have that catalog. You're right that is what it says. Hopefully SweetS10V8 can get this posted for you all. Honestly, every time I see any numbers for any of these cars it's different. Every horsepower number mentioned on this thread is correct according to this build sheet also. The only thing is, that it shows about four of five different 305 configurations. Also the 350 has a hell of a lot more torque than everything. Hopefully we can get this thing posted and you can all see what I'm talking about.
No paper will prove that the 305 from 89 had more power than the Turbo T/A also from 89, and the 350 there was only 1 configuration they came with from the factory, the one listed here.
Engine: L98 & 355ci
I got your email, but all i got was an empty folder. When I downloaded it, it was a .ink file. Has anyone heard of that before??
Anyways, Johhny I sent you intructions how to change it, but I just thought of an easier way.
Get the picture on the screen, then hit Ctrl + Print Scrn(just to the right of F12) buttons at the same time.
Now open up paint, powerpoint, or photoshop and paste it. You might have to open the picture program first, then hit "Cntrl + Print Scrn" then paste. Then be sure to save it as a jpg.
Car: 86 IROC, 04 Ram, 05 SRT-4, 95 CBR
Engine: LB9, 5.7 Hemi, 2.4 turbo, 600cc
Transmission: 700-R4
Axle/Gears: 26 spline 3.42's for now
i have the 86 305 tpi setup in my iroc. the only year gm detuned the camaro. the #'s were the same as the birds. in 86 these engines had only 190 hp stock and only gained about 30 hp up until 92. the 350's always had at least 10+ hp over the 305's. to say that and bird had a 255hp 305 from stock, i can only say PROVE IT!!! I have been messing with these damn third gens for 6 years and never seen one with a higher output going to the 305 instead of the 350 from stock.
It's a typo. You can tell by the metric conversions of the US hp numbers, US being (in parenthesis). 153 and 153 for the (205hp) LB9s; 168 for the ("255"hp) LB9; and 179 for the (240hp) L98. The 168(higher than 153, lower than 179) is right in line with the others and should have an hp number higher than 205 but lower than 240--225hp. So someone just double-typed the 5 instead of the 2.
And comparing torque, 295 is also right where it should be compared to the other combos, which would again fall in line with an engine of around 225hp, not 255hp.
But this isn't anything on johnny. He only told us what he read from an official source, AND he showed us the source. So thanks for showing us johnny and Sweet.
Car: 89 Firebird
Engine: L05 350 TBI
Transmission: 700r4-slippin' on it's last leg
Weel at least we al have closure now...And see, even manufacturers can make an occasional typo.
dbrochard
09-25-2015 04:56 PM
