Looking for vacuum diagrams
Car: 1987 GTA
Transmission: 4L60e
I've done a search and found rudimentary ones with handwriting, also very low resolution. My 87 GTA (recently resurrected) has vacuum leaks from hell...the heater just quit the other day. Over spring break, I plan on replacing every vacuum line on the car to fix the problem - but would like some kind of fallback plan if I find some have been disconnected from the major wreck.
Thanks guys!
Thanks guys!
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Look under the hood, there should be a label at the front of the hood over your right shoulder that gives you the schematic of your vacuum lines.
Car: 1987 GTA
Transmission: 4L60e
that's all fine and dandy...but if you haven't noticed I don't have the original hood. Well...I kindof do. It's crumpled like a coke can and I can't even get to the sticker.
Any other help?
Any other help?
Pac J
05-17-2020 10:44 AM
