Accel AFPR
Old 03-08-2004 | 10:43 PM
HaroGt14's Avatar
Accel AFPR
I just bought an Accel AFPR from Bottled91Z and it came with the actualy housing with the 8 or 10 bolts and this plate that kinda looks like a nickel.
I was wonfering if that goes on top of the regulator like so that the screw contacts it . . . or it goes on the bottom? Any advisre would be helpful.
Also I got a 2 5/8" gauge and I was wondering what adapter I need to make the -4an line connect to the shrader valve.
I have been on the phone with summit and they don't know anything about it. And Acell isn't open tomorrow and I was to get this on ASAP.
Thanks,
Sean
Old 03-09-2004 | 12:55 AM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: Accel AFPR
Thanks,
Sean
The nickel piece goes on top. Make sure you use it.
Old 03-09-2004 | 09:29 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Re: Accel AFPR
The test port is already 4AN, just remove the valve core and you're good to go.
Fanatic1074
10-03-2022 05:57 AM
2012sergen11
10-13-2015 07:38 PM
Reid Fleming
10-10-2015 09:56 PM
efiguy
09-27-2015 01:30 PM
355tpipickup
09-04-2015 05:32 PM
Quick Reply: Accel AFPR
