Car stalled, won't start up again
Car: 1989 Firebird Formula
I was driving the other day and my car just died all of the sudden. It stalled out and the check engine light came on. I tried to start it again and it would crank strong but wouldn't kick back over. I'm getting fuel to the rails and the pressure is fine. The battery is fine...I checked it. Anyone have any idea what could have happened? I have a tpi 350. Thanks in advance.
1 Post
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
Same thing happened to me it turned out to be the little ignition module inside the distributor cap. I changed it out and BAM the car fired, they have been known to fail and the car will shut off as you are driving.
Just wanted to update and thank everyone...it was the module in the distributor...changed it and it started up right away...also seems to run a little smoother too. Where would I be without this group? Thanks again!
