Who has a L-98 and 1.6 rockers?
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
FWIW - When I was running that combo I had to enlarge the holes. I don't think this is optional. I was running a hot cam (.525 lift).
Perhaps others will chime in.
-Schultzy
-Schultzy
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
when i used the LT1 cam, i had no problems. http://www.fl-thirdgen.org/rockerswap.html
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
Im running an LT1 cam in my 305 with 1.6 rocker and with stock heads and after asking this questions along time ago before putting the rockers on, MRR23 replied and said it wouldnt be a problem and it ended up not being a problem for me aswell.
Car: 1990 Iroc-Z
You'll pick up a few horses sure, but I don;t know about noticing a difference without some sort of control like a base run at the track or dyno. Maybe 10RWHP on a stock 350... just a stab.
UltRoadWarrior9
04-28-2020 10:39 PM
TX-SleeperC5
09-24-2015 03:13 PM
