Opinion on cam for the 400 build up
Car: 82 ElCamino, looking for a 3rd gen
Engine: 305 TPI(427SB in progress) 730 $8D
Transmission: THM350 (Getting a 4L80E soon)
Axle/Gears: 10 Bolt w/ 2.43 gears :(
![help](https://www.thirdgen.org/forums/images/smilies/help.gif)
![Confused](https://www.thirdgen.org/forums/images/smilies/confused.gif)
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
Take a look at the flow numbers on the Dart Pro 1 heads. If the intake /exhaust ratio is 75% or above, go with a single pattern grind.
Also, the cams you listed have 110 lsa. You will want to get a cam with a 112 lsa or idle vacuum may be a problem.
I'm running a Comp XE solid roller custom grind 242/242 .608/.608 112 lsa installed at 109 degs. This cam coupled with the Brodix heads seems to make some serious power.
www.geocities.com/dzperf
ambainb
04-25-2016 09:21 PM
Thornburg
08-25-2015 01:46 AM
