1991 Z28 350 tpi dies on occasion when started
Car: 1991 Z28
Transmission: stock
My Z28 dies on occasion when I try to start it. I have to hold the gas pedal down and put it in gear to work. It doesnt do it all too often, mostly in the morning or when its cold. I live in California so it doesnt really get freezing cold. When I bought new tires the other day, my car was acting up at the tire shop. I ran into a bloke there who had an 80's vett and he said its my IAC valve. Does that sound right? I have good oil pressure. Where is the IAC valve located? I looked through my camaro book and it didnt have a good decription on its location. Cheers sticky
the IAC stuff should be attached to the underside of the TB. i never had mine off before so i dont know to much about them.
they get dirty and usually need cleaning after awhile.
the connector is on the passengers side of the throttle bottle.
Car: '01-Z71, 2ND GEN CAMARO, 3RD GEN Z28
Engine: 5.3, 383 STROKER, 350 TPI
Transmission: 4L80E, TH400, 700R4
The IAC is located under the tps sensor, its on the front left side of the throttle body. It has a a square 4 wire connector plugged into it. IAC stands for Idle Air Control valve. I just replaced mine, i was having the same problems as you. There is a link in the tech articles on how to adjust it.
Good luck..
Good luck..
Sanjay
08-12-2015 03:41 PM
