TPI at High altitude - MAF or SD?
Car: 85 SS
Engine: 305 L69
Transmission: 2004R
Axle/Gears: 7.625, 3.73
Anyone know which TPI system works better at higher altitudes? I'm at 5344' and some of my "road trips" include going as high as 10,000 to 11,000 ft of altitude.
Thanks,
Larry.
Thanks,
Larry.
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: TPI at High altitude - MAF or SD?
Thanks,
Larry.
Thanks,
Larry.
Car: 85 SS
Engine: 305 L69
Transmission: 2004R
I had read somewhere where SD was better suited to higher altitudes like ours but never could find anything to cooberate it.
Thanks,
Larry.
Thanks,
Larry.
Thanks,
Larry.
Thanks,
Larry.
Here is a link comparing the two systems. It doesnt mention altitude at all. http://www.carcraft.com/techarticles/24549/.
Car: 85 SS
Engine: 305 L69
Transmission: 2004R
Looks like the thing that would "maybe" make a difference would be the way SD uses vacuum as part of it's programming. If I remember right vacuum increases as altitude increases(or is it the other way around?!). Whatever the case if the SD system makes it's calculations from vacuum then that could explain why it "might" work better for altitude changes. Of course it may not be that precise. Looks like it still boils down to preference and whether or not you are doing mods.
Thanks for the help.
Larry.
Larry.
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
They both should be fine but the MAF system will work better as it measures the mass of the air which means it auto compensates for differences in humidity, altitude and temperature.
Car: 89 Formula 350
Engine: L98 w/ Stealthram
Axle/Gears: 9 bolt 3.27
Vacuum is actually any pressure less than current atmospheric pressure. At sea level, atmospheric pressure is 14.7 psi. It is less at higher altitudes. I believe Denver is somewhere around 10-12 psi. I would think, that a MAF system would be better suited to higher altitudes than SD because of this.
NBrehm
08-25-2015 11:49 PM
Sanjay
08-12-2015 03:41 PM
