3.42's or 3.73's??
Car: 2000 Trans Am and a 85 Iroc-Z
Engine: The Mighty LS1& 305 just beat meTPI
Transmission: 4L60E and 700R4
3.42's or 3.73's??
I will be adding a ported set of heads this week hopefully and I was thinking of getting some gears in to replace my 3.23's. The 3.42 jump doesn't seem like much to me and the 3.73's seem like they would work better. I do a lot of driving but milage is not an issue to me as it is bad anyway. I am also getting a 2500 stall converter as well in the coming weeks. So if that helps. What do you all think would benifit me more the 3.42's or the 3.73's? Thanks.
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: 3.42's or 3.73's??
Thats what I was thinking as well. I am adding that high stall converter and the 3.73's seem like they would work rather well in this combo. I wanna try and stay in the meat of the TPI band. I just wanna get a good enough launch to stay ahead long enough. Thank you for answering.
Car: 85 IROC
Engine: 355 CI n/a
Transmission: 700 r4 w/3500 Coan
Went both routes when mine was TPI...If you want to stay in your powerband, 3.42's are the way to go..I lost almost 2 tenths with 3.73's the TPI more than compensates with its torque. Also if you ever plan on spraying, 3.42's will keep you out of redline in the quarter..
Car: 1990 Iroc-Z
I would go with the 3.42s
The TPI low end, and that stall converter will launch you HARD. The 3.42s will maintain a really nice acceleration, while not topping you out too soon (keeping you in the powerband LONGER)
3.42s!!!
3.42s!!!
Damn mixed reactions huh. Now I am confused.
Bottom line, 3.42.
The only reson to run more gear on a TPI motor was if you were planning to drive taller tires, such as a 27" or 28" slick at the track.
For the street 3.42 is what you want, 3.73 will not be your best street option. The converter you have is fine, dont change it.
Car: C-20
Engine: 260 boat anchor Mexican 350 (crate) TPI (MAF)
Transmission: THM-400 I turn 3500 (which is where my pos engine's power starts droping off) at 80 I need a 4L80-E
you should put in your 2500 stall converter and then decide if you want to change your ratio.
Car: 85 IROC
Engine: 355 CI n/a
Remember: TPI motors are rich in torque: Don't out-stall your powerband..2800-3000 is plenty with 3.42's
UltRoadWarrior9
04-28-2020 10:39 PM
