Question for everyone running aftermarket TPI and atleast 350rwhp
Old 04-20-2004 | 09:29 AM
  #51
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
PITA, but I would not make another move until I had put a degree wheel on the cam and made sure where it was. The slop in the crank keyway, cam keyway, gears and chain can ad up to a cam that you thought was installed straight up, but is nowhere near where it should be.
All quality timing chain sets have multiple keyways in them, necessary to get things timed correctly because of the "stacked" tolerances. A cam out of time will result in a major dog.
Just so you don't feel dumb, my first engine I plastigauged all the bearings twice, but was so busy playing with the plastigauge, I forgot to put in the rear main seal. Didn't notice until we fired it off and oil came pouring out the back of the crank. (DUH!!!)
Good luck
Troy
So Cal
Old 04-20-2004 | 10:42 AM
  #52
OMINOUS_87's Avatar
Well I can now officially tell you that you have a serious problem.
Just finally got my SR machine to the track, and she ran like a SOB, yikes
Traction was poor but otherwise, lookout!
https://www.thirdgen.org/techbb2/sho...hreadid=236033
R/T____________.846
60'____________1.943
330'___________5.282
1/8_____8.079@87.91
1000'_________10.489
1/4___12.527@113.55
And as far as the CAI I have, its the el cheapo deluxo Home Depot model.
Attached Thumbnails Question for everyone running aftermarket TPI and atleast 350rwhp-cai.jpg
Frozer!!!
01-19-2024 04:55 PM
86IROC112
08-17-2015 02:00 PM
redmaroz
08-16-2015 11:40 PM
gta power
08-13-2015 06:15 AM
squiggy2
08-09-2015 09:30 PM
Quick Reply: Question for everyone running aftermarket TPI and atleast 350rwhp
