Why Hyd. Roller cost so much $$$
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Why does a hyd. roller cam cost so much more than any other cam? For example:
Crane Powermax Cams
194* 204* 401" 423" p/n crn-114112 Standard Hyd. w/lifters
$154.95
194* 204* 407" 429" p/n crn-104211 Hyd. Roller, without lifters
$269.88
Difference in $114.93
Is the actuall cam (not profile) different?
Just another way of making more money?
Crane Powermax Cams
$154.95
$269.88
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Roller cams are made from billet steel rather than soft iron like flat tappets. It's more expensive to machine.
Also, even if a roller and a flat tappet had the same profile the roller still makes more power through the RPM range, even though peak power will be nearly the same.
Car: GM & Jaguar
Engine: Various
Transmission: Various
Axle/Gears: Various
KO1
16
10-15-2015 05:00 PM
