ls1 injectors
Car: 67 camaro
Engine: 383 accel dfi
Transmission: t56
ls1 injectors
wil ls1 injectors work on a tpi?my buddy has a new set i can have for nothing.they r 28lb/hr.do u think these are enough for the motor i have?here it is.
383 bottom end
comp cams roller 224 intake 230 exh.
.503" intake .510" exh.
acell lower intkae slp runners
aprox 400 hp and 465fb/tq
383 bottom end
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
If the injectors are standard Bosch style they will work. You will need to get a custom burned PROM to properly operate them though. Also, you need to know if they are low impedance or not. If they are they won't work. 28lbs/hr is right on the edge of a 400HP motor, but that's good. Having too much injector is bad. Having too little is bad. Having just enough with a small safety margin is right where you want to be.
They'll work just fine, i have a set on my 91 Formula. You do need to know that they are flow rated at 58 PSI and so will have a lower flow at the TPI's 43 psi. Also you'll need a chip burned for the different injector size.
Statflow2 = Statflow1* (SQRT (SysP2/SysP1))
Statflow 1 = injector's rated flow @ given pressure (28 lbs/hr @ 58 psi)
Statflow 2 = actual injector flow rate with proposed new fuel pressure
SysP1 = existing system pressure (58 psi, stock LS1 pressure)
SysP2 = proposed system pressure (43 psi? whatever you're running now)
This formula will let you know the flow characteristics of the injectors in your engine, because they won't be 28 lbs/hr injectors when operating at lower fuel pressure.
Going to the chip burner with this information will result in a much better running engine, and make you look smart too!
dbrochard
09-19-2015 08:13 PM
