Post your TPI set ups here
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 92 Camaro RS, 87 Iroc-Z
Engine: 305, 413 CID in progress
I'm getting ready to build my first 350 soon and i'm not quite sure how i want to setup my TPI system. I'm looking to make peak power at around 5,500RPM and make hopefully 280-320 HP.
So please post your set up, how it has worked for you so far and why you decided to use your setup. Thanks for your time.
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
Ill start with a basic one:
100% stock L98 netted me 14.25@95 with only sub frame connectors with 145,000 miles on everything.
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
I went with a Lingenfelter super ram upper and edelbrock high-flo lower intake. I'm happy with this combo. The car is running 13.50's with a stock engine. Plus i think this combo will work well when I rebuild the motor with LPE 219/219 and AFR195's. anyway you can see what has been done to the TPI aswell as other parts of the car below.
Car: 2004 GTO
See the first page of my site: www.cardomain.com/id/formul8
Car: 92Z28
Transmission: A4
In my sig. It peeks lower than 5500 though, at 4400. I think that's about all the stock runners can manage. I like it alot.
Good luck,
Charlie
Good luck,
Charlie
Okay here is my TPI setup with a 1989 L98 350CI. Stock Edelbrock highflow base, stock early SLP runners, slightly modified factory plenum. Screens removed from MAF. 256 RWHP at 4200RPM and pretty flat to around 5100RPM. Problem there is the reground factory cam with 117.5 LSA. This month I will have a ZZ4 cam installed with a 112 LSA and this should increase the HP and move the peak up the RPM range. Also will port match everthing and siameese the SLP runners a lot more. Also ran a 13.8 and 102 at the track with the set up. I will also be installing some suspension mods as the car needs them in the worst way. Allen
355ci
Cast crank
Melling Oil Pump
Summit Stage II rods
KB Hypereucraptic pop-up pistons
AFR 190 heads
Comp Cams XE282HR Cam
Comp Cams 1.5 Roller rockers
Crane Cams Pre-roller hydraulic roller lifters
Crane Cams Hardened Steel push rods
Port matched Edelbrock big mouth intake manifold
Port matched Accel SuperRam
BBK 52mm Throttle Body
Ran a best of 13.7 @ 102mph on a BAD fuel pump.
No idea what it runs now . . .![Frown](https://www.thirdgen.org/forums/images/smilies/frown.gif)
Cast crank
Melling Oil Pump
AFR 190 heads
Here's a good one that will work with the stock chip and get you low 13's at about the horsepower you're asking for:
350 cubic inches (or 355, same thing)
Trick Flow 23 degree heads
ZZ4 cam
SLP 1 3/4" headers
Edelbrock or Accel TPI intake manifold
SLP or AS&M Siamesed runners
Any good 3" exhaust system you like
Are you using an automatic or a stick shift? If an automatic you WILL need to get the trans rebuit to handle the horsepower, and dont forget a good stall converter too, in about the 2400-2800 rpm range. For a stick shift, be careful with the T5, and get yourself a good clutch like from McLeod.
ZZ4 cam
SLP 1 3/4" headers
Cool thanks for posting all your setups
Kevin91z thanks especially for your post
Would that setup work as well or about as well with a set of World Products S/R Torquers or similar heads? I dont exactly have the funds for aluminum heads right now.
I originally was going to use a spare 700R4 transmission and upgrading to a t-56 later on when funds are more plentyful. But if i'm going to have to rebuild it i might as well just go for the t-56 right off the bat. Thank you very much for your tips.
Also where can i find a zz4 cam? i cant find it anywhere outside of crate engines
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
The biggest thing to remember is to match your intake and TPI system to your engine. It sounds like you are already planning heads and a cam swap, so you're already on the right track.
You could also go with a miniram or LT1 conversion intake with the T56. You will lose some low end, but the top end will pick up a lot. You will be able to determien where the car launches, because it's a stick.
If the car will stay an auto then stick with a setup that is closer to stock (ported plenum, SLP/LPE runners, hi-flow base), unless you want to run a fairly high stall converter.
Also, you might want to reconsider the ZZ4 cam. It is really designed for a carbureted engine, and may not have enough LSA to work properly with a TPI system. I would stick with a LPE, TPIS, or SLP grind.
ZZ4 cam
SLP 1 3/4" headers
ZZ4 cam
SLP 1 3/4" headers
my set up right now. basically only major mod being the headers. went 14.4@96 before changing back to the stock runners:
Car: GM & Jaguar
Engine: Various
Transmission: Various
Axle/Gears: Various
Exhaust:
Edelbrock Smog Legal TES Headers
Factory 3" Single Exhaust
Flowmaster 80 Series 2-Chamber Muffler
No Cat
Injection:
Accel 22lbs Injectors
Hypertech Thermomaster Chip
Polished Throttle Body with Air Foil
Port Matched Intake, Runners, and Throttle Body
Throttle Body Coolant Bypass
BBK Adjustable Fuel Pressure Regulator
K&N Air Filters with modified airbox
Valvetrain+:
Aluminum roller rockers
Comp Cams Extreme Energy Cam
SpeedPro Hypereutectic Pistons
Rhoads Progressive Lifters (Swapped out)
March Underdrive Pulleys
Ignition:
Pertronix Flame Thrower HEI Kit
MSD 6A Box
MSD 8.5mm Wires
Bosch +2 Platinum plugs
That's all I can remember, there's probably something else hiding in there
The cam was too lumpy for a 305, but it ought to work better in the 327 with a higher stall converter (or stick). It was gutless off the line, but damn it made some serious power at 2800 to 5500+!!! It's a very strong setup that got 18-20mpg - pretty killer if you ask me.
No Cat
Injection:
Valvetrain+:
Ignition:
MSD 6A Box
MSD 8.5mm Wires
![Roll Eyes (Sarcastic)](https://www.thirdgen.org/forums/images/smilies/rolleyes.gif)
ZZ4 shortblock
AFR heads (10:1 compression)
Comp Cams 212°/222°
Borla stainless exhaust headers
MiniRam intake
Custom Programmed EPROM
52 mm throttle body
Factory ignition system
Comp Cams 212°/222°
MiniRam intake
52 mm throttle body
Engine: L98 & 355ci
Originally posted by ULTM8Z
Don't know unfortunately. For the last year, I've been trying to diagnose and solve a idle misfire.
However, prior to the problem, it was running fine for a few months with my then-new Miniram and a ZZ4 camshaft (which only has 208° intake duration). Even with that smaller cam, there was no lack of power over 5000 rpm. I haven't tuned the engine for the new cam because of the misfire problem, but even now, it feels like it's going to be extremely strong.
I wanted a near-stock idle with good all around performance and good fuel economy (I also have a TH700-R4). I'm sure this cam will give me both. Heck, if a stock ZZ4 can make 355 (and it does, as I've witnessed dyno pulls on one), then the addition of AFR heads and bigger cam should get me darn close to 400 hp (which is fine with me!).
Car: 1989 IROC-Z
ZZ4 cam
SLP 1 3/4" headers
ZZ4 cam
SLP 1 3/4" headers
Car: 1991 Z28
Engine: 355 TPI
VortecZZ5 heads
LT4 Hotcam
Edelbrock TES headers
SDPC Base
SLP Runners
Catback? -Still deciding
S10 Converter
Still being put back together so hopefully in a few months I'll have some numbers
VortecZZ5 heads
LT4 Hotcam
SDPC Base
SLP Runners
S10 Converter
Zachattack0925
08-12-2015 09:54 PM
Sanjay
08-12-2015 03:41 PM
