Winaldl work with 85 tpi?
Car: 1991 camaro RS
Engine: 305 Carb
Will Winaldl work with a 1985 trans am with TPI? A buddy of mine has this car and he doesnt know if it will work or not.
Car: 1987 Firebird Trans AM
Engine: 383 TPI...very soon
Transmission: TH700R4
I have a 1987 Firebird T/A with the 165 ECM and a 305 TPI, WinALDL works fine with a 1 transistor cable, although I do have to put a 10k resistor across ALDL Pins A and B to get the ECM to send data.
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
my understanding is that it will work, but you won't be able to get as much data out of the 85 ecm as you would from later years due to the slower baud rate.
this is why some people, including myself, swap to the 86-89 ecm.
there is a tech article on this on the front page.
Car: GM & Jaguar
Engine: Various
Transmission: Various
Axle/Gears: Various
Originally posted by del91_305
His is a 85 With the MAF TPI setup, wonder if it would work also?
1992rs/ss
05-19-2020 07:02 PM
Sanjay
08-12-2015 03:41 PM
