Holley Stealth ram gasket part #
1 Post
Car: 89' IROCZ
Engine: 5.7 L98
Does anyone know the holley part # for the plenum to intake manifold gaskets? I tried to get this form holleys website, but it is a nightmare with my dailup modem. My local part store can order it if I have a part #, but they could not find it in ther catalogs.
I didn't bother with it, RTV works just fine.
Just clean the surfaces real good and apply a little RTV black and your all good.
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
RTV on mine also. another thing. for those of you that have the HSR and haven't submitted your car at www.stealthram.com , go to the HSR cars section and submit your stuff and i'll add it.
the holley part number is 108-119
but I would suggest you make your own useing a new gasket as a pattern from 1/16" thick rubber sheet gasket material found in 4" x 4" sq sheets at most hardware stores for under $1.50 as they last much longer, use a thin bead of yellow 3M weatherstrip adheasive for a leak free seal, carefull work with an exacto knige and a marker makes producing gaskets easy
1 Post
Car: 89' IROCZ
Engine: 5.7 L98
Thanks for the advice. I was using RTV, but it would squish out and leave a lump on the inside. I'm concerned that it would disrupt the air flow, but judging from the 1/4 mile times you guys are getting it looks like it's not a problem. While I have all you HSR owners on this thread, What is a good chip, mine came with a hypertech thermomaster and I'm not totally happy with it. I should give you some more details about my car
K& N filters, gutted air box, TPIS airfoil, HSR, AFPR set to 47 psi, rebuilt engine from jasper, MSD 6AL, MSD wires, rebuilt 700r4 by previous owner w/2500 stall, Borg warner 9 bolt w/ 3.7 gears, 17" ronal wheels w/275/40vr17 goodyear, KB subframe connectors, 1 1/2" front 1" rear sway bars, 170* thermostat, new cat, cat back w/ flowmaster muffler w/ cutout.
Car: 86 IROC
Engine: 6.2
Axle/Gears: 10 Bolt 4.10
IT SQUISHES OUT WHEN YOU USE TOO MUCH. JUST USE A VERY THIN FILM LIKE YOU WOULD AROUND THE WATER PORTS ON YOUR HEADS. IT WON'T SQUISH OUT IF APPLIED CORRECTLY. I PUT THE RTV ON MY FINGER TIP AND WORK IT AROUND SLOWLY, AND KEEP GOING OVER IT UNTIL IT IS DONE.
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Engine: 360 HSR
the only good chip for the HSR, and any other engine, is a custom burned one from dyno tuning. no generic chip will suffice.
9192camaro
16
02-03-2019 12:21 AM
LT1Formula
20
11-14-2015 12:02 AM
L98GTA87
08-11-2015 06:55 PM
