Cam for stealth ram
Car: 92 quasar gta
Engine: Nothing
Transmission: Nothing
Axle/Gears: 4.11s
Cam for stealth ram
What would be a good cam for a stealth ram setup
so far im running
- stock 350 bottom end
- pro action 180 cc heads, ported and polished
- edelbrock 1 5/8" shorty headers
- 24 lb injectors
- stock throttle body
right now i have a 218/218 cam but i think it might be a little small.. should i bother to change it or would it be alright?
also what would a good stall to run with this setup?
so far im running
- 24 lb injectors
1 Post
Car: 1991 Z28
Whats the lift of the cam? what kind of cam is it? You could always try it and see. Personally I would just go for a bit bigger cam...like a 224/230 duration @.050 and then learn the DIYPROM aspect. Youll never get it to run "right" without doing some tuning.....even with the 218 cam. Good luck....
Car: 92 quasar gta
Engine: Nothing
Axle/Gears: 4.11s
oh im well versed on tuning i have all the stuff to make it work.. guess i forgot to add that..
its a crane powermax 2050.. says its an lt1 cam..
218/218 w/ 541 lift.. 116lsa
Car: Faster
Engine: Than
Transmission: You!
If you want to stay on the smaller side but still want to make some decent power, you should try the Comp Cams (XR269HR-12).
The LSA on your current cam is not all that great for a stealth-ram. That HSR intake will make peak power in a higher RPM. Hence, the 112 LSA on the cam I mentioned will compliment your intake a little better.
Just my $.02
Just my $.02
Car: 92 quasar gta
Engine: Nothing
Axle/Gears: 4.11s
Only place i could find a XR269HR-12 was for an LS1??
the car isnt driven much so i dont mind something too bad..
Car: Faster
Engine: Than
Transmission: You!
Look at comp cams online catalog under comp cams xtreme roller grind
the XR269HR-12 is for hyd. roller cam equiped SBC (non-LT1)
specs are:
.495/.503
218/224 @ .050
112 LSA
108 ICA
Click here
Hope that helps!
specs are:
.495/.503
218/224 @ .050
112 LSA
108 ICA
Click here
Hope that helps!
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
click the green banner. look in the HSR CARS section and see what others have used and what times they are running.
Car: 92Z28, 99SS, 83Z28 & 86GTA
Engine: 421, LS1, 327Turbo & 383
Transmission: T-56, 4L60E, T5 & 4L60
Axle/Gears: 4:10, 3:42, 2:73 & 3:27
I'm with Mike on this, that Comp XR269HR-12 is a sweet cam Same with the size up.
Car: Faster
Engine: Than
Transmission: You!
Yea, I run the next size up in my TPI 355. (XR276HR-12)
Even though I run the bigger one, they are both really nice cams! Just be prepared to do alot more PROM tuning if you go with the XR276 .
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
I had the XR276HR-10 (110CL) cam on my 350 HSR, It was slightly soggy on the bottom end, but screamed up top. I see you are running 180cc heads. In that case I would go with the 269 cam.
Car: Faster
Engine: Than
Transmission: You!
It was slighty soggy down low and screamed up top cause you had the 110 LSA cam. You wouldn't of had that problem with the 112 LSA XR276.
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
I have a cc306 in mine. I like it a lot. Still needs a lot of tuning though.
230/244 and .544/.576 w/ 1.6r
Car: 92 quasar gta
Engine: Nothing
Axle/Gears: 4.11s
ive always liked the power number the lt1s can put down with a cc306... can it be run safely with stock lifters??
i forgot to add that im also running a rev kit so that should help a bit
i like the numbers of that 276 cam as well.. but not the price as its like 375 from comp
im lacking any sort of dyno or a wideband so most of my tuning is done on some back highway with a g-tech and that datamaster tuning program.. drivability is easy but WOT is not too fun
Car: 92 quasar gta
Engine: Nothing
Axle/Gears: 4.11s
260 isnt bad
there is places where you can get them custom ground for like 220$ so i can basicaly pick any numbers and lobe profiles to roll with..but with all that flexibility comes nothing but doubt
i dont want to have to change it so ill do alot of checkin setups before i finally get one
Stangski09
11-14-2015 01:27 PM
