Adjustable fuel pressure regulator
Car: 1989 IROC-Z
Yes its worth it...but they are not cheap...TPiS, Holley and Accel all make them... U can see a big gain in using one...
Jason
Jason
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
I would think that if everything under your hood is stock then you probably wouldnt benefit from an adjustable FPR (IMO). My engine is modified. My stock pressure was at 37psi when I hooked up the regulator and pressure gauge so I have since adjusted it to 45psi and it responds and runs much better. You will need some kind of fuel pressure gauge so you know what pressure you have and can then adjust accordingly. I have the BBK FPR and an Accel gauge that mounts to the fuel rail. Both parts were 70 bucks each. I am sure someone will correct me if I am wrong about needing one for a stock set-up.
Car: 1989 IROC-Z
Yea they are more for the modified engines but I have seen some people benifit alittle bit by installing one on there stock 305/350. I bought one from TPiS for my 350. No clue how it will aftect the performance but I know it will help...OH and just outta curiousity why is holley the better brand. I would think they all serve the same purpose so how is one better than another?
Jason
Jason
Get the holley one. I got one from ebay for 60 bucks brand new!!! (no plenum gaskets though)
It has a much easier to work with design as opposed to the others that use a screw which either interfeers with the plenum or is simply a PAIN to get to for adjustments.
Trust me, get the holley. - although, i also heard that the JET piece is good too .
Car: Faster
Engine: Than
Transmission: You!
The holley is a billet unit that utilizes a round dial on top to adjust pressure. You can adjust pressure with your finger rather than having to fish a wrench in there to access a bolt.
I wouldn't use anything else!
Guess I shoulda done a little more research first cuz my BBK bolt hits my plenum etc. and it pees me off. I am calling BBK for some answers and to find out if I can switch to a shorter bolt.
Car: 1990 IROC-Z
Engine: 350 L98
i saw the holley one on summit, but it only says it's for 305/5.0's. would it still work on my 5.7 tpi? http://store.summitracing.com/partde...LY%2D512%2D501
1 Post
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
I had the Holley AFPR on my car until the diaphram broke and was pouring fuel into my plenum via the vacuum line I've had it off for about a year now. Anyone know where to get a replacement diaphram or if Holley warranties them or anything? THANKS!
Car: Check The Sig
Im deffinatly getting a Holley. Might have to ask santa for one... along with some nice pro mags and a decent set of springs... a hypertec fan switch would be nice too.. hummm
Car: 86 "Ram Air" IROC
Engine: 305 5.Slow
Didnt call BBK. Took mine back to Checker Auto where I bought it and said it was defective and then bought me a Holley! Much better!
1 Post
Car: 92 Z28 heritage
Engine: 5.0 TPI
For fear of sounding ghetto, I will first preface this: I am not into sh*tting up my car or anyone else's. I love a clean install on a clean engine just as much as the next guy. But....
You could always just modify your stock regulator and save some money. After spending $50 on my crane cams AFPR, I realized I could have just as easily dirlled a hole on the top of my regualtor cap, run a tap through it, drop a coin in over the spring and run a $.05 bolt into the threaded hole I just made. THIS IS EXACTLY WHAT I GOT FOR $50! I cold have just spent $.10.
Or if you are real broke, you could just bump your stock fuel pressure by shimming the spring with coins, a nickel would give you a good 4-5 PSI.
Once again, I know this sounds ghetto, and I appologize!
1 Post
Engine: 5.0 TPI
Originally posted by CaptPicardsZ28
my new fpr bolt was so high that it hit the side of the plenum and made it real hard to adjust and or put the plenum back on.
9192camaro
16
02-03-2019 12:21 AM
