Tested Injectors...
Old 10-06-2003 | 07:19 PM
Christos's Avatar
Car: 1986 Iroc Camaro
Transmission: Th700R4 Jr. Raptor
Tested Injectors...
All showed up at about 16.4 ohms.
When I tested my cold start injector, it shows up as 4.1? Does anyone know if this is normal or not?
Old 10-06-2003 | 07:27 PM
prOject-IrOc's Avatar
Car: 1990 Iroc-Z
hey how exactly do i go about testing them? My car just died on me this morning and i think it is my injectors? thanks.
Old 10-06-2003 | 07:40 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Take a multimeter and set it to OHM's, then pull the the connector off of the injectors and measure the resistance across the pins on the injector. Resistance should be somewhere around 16 OHM's.
And to Christos, yes, your readings are normal!!
The Trickster!!!!!!!!!!!!!
Old 10-06-2003 | 09:01 PM
Christos's Avatar
Thank you. Even for the CSI?
I thought 4 ohms was a bit low, but then it isn't the same as the other injectors.
Old 10-06-2003 | 09:54 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Yes, 4 OHM's is normal for the cold start injector and you are welcome.
Linson
09-25-2021 07:55 PM
RedLeader289
05-28-2019 01:47 PM
oil pan 4
Fabrication
10-06-2015 11:56 AM
Spyder_TheGamer
10-02-2015 12:25 PM
Eric-86sc
09-28-2015 11:37 AM
Quick Reply: Tested Injectors...
