165-730 swap now no timing advance
Old 10-04-2003 | 03:16 PM
formulajoe_2's Avatar
i repinned my 165 harness to work with the 730 ecm. The computer is not advancing the timing as rpm increases. I can set the base timing but when i plug the tan/black wire back in, it makes no difference. It just stays at 8* or whatever. What all would cause this? BTW, everything is in question here because ive never had this car running..i bought the car with a blown motor (L98) and put a new motor in it and also did the 730 swap, so im not real sure if the esc module is good, etc, etc. I just need to understand this esc circuit and how the 730 differs from the 165 as far as the esc goes. BTW i am getting a code 42 and 43. Any help would be appreciated.
Old 10-04-2003 | 03:56 PM
kevinc's Avatar
Car: 1982 Z28
What MEMCAL are you running? Given the ESC board is located on the MEMCAL there's need to be running the right one.
Old 10-04-2003 | 04:24 PM
im running a 730 out of a 91 Fbody (L98) so it should have the correct memcal.
Old 10-07-2003 | 03:02 PM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
formula
did you replace the knock sensor with a 90 up sensor, I had this problem when I converted from 165 to 730, also a bad knock sensor connection will cause this as well
jharrison5
08-19-2015 05:53 PM
Armored91Camaro
08-12-2015 09:41 AM
armybyrd
08-10-2015 09:23 PM
Thirim
08-09-2015 06:19 PM
djmarch
08-09-2015 05:27 PM
Quick Reply: 165-730 swap now no timing advance
