Heated O2 sensor or stock?? which is better for me
Old 10-03-2003 | 06:35 PM
wyclefsirocz's Avatar
Car: 1989 Iroc z hardtop
Engine: peanut LB9
Transmission: slopomatic TH700R4
i've heard of people installing heated o2 sensors. which one should i install and whats the advantage of the heatd O2 sensor--
Old 10-03-2003 | 07:47 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
You should be able to go into closed loop quicker and stay in it longer at idle, with a HO2S. That said, normally only time to upgrade is when installing headers (due to the primaries cooling off and not retaining the heat that an exhaust log manifold will), otherwise a regular O2 sensor should be okay.
Old 10-03-2003 | 09:56 PM
strokedtpi's Avatar
Car: 1990 Formula 350
Engine: 5.7
what types of problems could this overcooling by the headers cause......any error codes or such..?
Old 10-04-2003 | 10:55 PM
Morley's Avatar
It could keep you from entering closed loop or staying in closed loop if it gets there.
13sec83trans
Carburetors
22
11-28-2015 09:26 PM
Cam-aro
Camaros Wanted
11-12-2015 03:35 PM
85 Jimmy
09-30-2015 07:56 AM
BLK87Z
09-18-2015 11:29 PM
FormulasOnly
09-10-2015 09:07 PM
Quick Reply: Heated O2 sensor or stock?? which is better for me
