Washed engine, now it won't run right?
really need some help! I washed my engine and covered the coil and breather up. Put two cans of degreaser on it and sprayed it all off. Now it won't idle and has a huge miss in it? The car ran perfect before then. Checked the plug wires and all connecters. Any ideas? Thanks
88 TA with a L98 700r4 5.7 TPI
Car: 1989 Formula 350 / 2000 Lightning
Engine: GM HO 350 Crate (Vortec headed w/TPI) / SC 5.4 330
Transmission: Rebuilt 700R4 (Raptor Rebuild Kit)
Water in the distributor.....let it dry out for awhile and you will be good
You got the throttle position sensor wet, don't do that. Is the idle surging over a wide range of RPM's? Does it lack power when hitting the gas? Replace the TPS and don't get it wet again.
