TPI to LT1
Car: 1986 Trans Am
Engine: 5.7L TPI
TPI to LT1
I'm not personnaly doing this mod but i was curious on what I would need to convert to a LT1 from a TPI, also maybe what I can re-use and if it would pass Smog/Emmissions, (without having hook-ups).
Car: 1990 GTA
Transmission: manual/t56
www.lt1intake.com You should find everthing you need on johns do it yourself page.
Car: 1986 Trans Am
Engine: 5.7L TPI
thats a great source but one problem is, thats for a 1st gen, says nothin for emmisions or the wiring and such involved in a 3rd gen
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
cause i know of plenty of people who have made that swap into 3rd gens?? what kind of wiring are you talking about... injectors?? tps?? explain please...
Car: 1990 GTA
I think you misunderstood what you read. 1st gen means a 1st gen smallblock. gen 2 is tha lt1 and gen 3 is the ls1. A 350 or 305 in a third gen camaro is a first gen smallblock. I know the the lt1 intake is not emissions legal because you can't use a egr on it( I think some people have talked about a corvette type egr but I don't know anything about it.)
Car: 1989 Trans Am
Engine: 355 HSR
hell my 97 anniversary edition lt1 has an egr on it hmm and they are very much so emmission freindly thats why there are so many fuggen wires attached to the ***** and i think if he does a search there is something about fitting their intakes or someones modified intake and gen 1 engines too
Car: 1990 GTA
sorry, I should have said a modified lt1 intake. Once modified for the distributor there is no room for the factory egr. Like I said john's site should tell you what you need to know. I'm sure a email to john himself should get you any other answers you need.
I think he is asking what has to be done to put an LT1 engine in his car - not just an LT1 intake swap. There are several posts on this. I strongly considered it while parting a 95 Trans Am t56 car, but I didn't do the swap due to not wanting to notch the crossmember for the A/C compressor. As well as the fact that you can accomplish better results with a std small block without all the hassle. It's cheaper and easier to upgrade an L98 than to swap to the LT1. Besides the intake difference, (which can be swapped as mentioned) the only other real improvement on the LT1's are the heads. I know the claim better cooling, etc., etc., but really a L98 short block with improved heads and intake will do just as good of a job. If the LT1 was such a great design, why did it get aborted after only 6 years of production? Also, why did it not replace the older design engines in the truck/van lines?
Car: 1986 Trans Am
Engine: 5.7L TPI
hmm alright cool, thank you all for the info, it got me thinking alot, but my main question is, would it be legal to put a LT1 in a thirdgen
Car: 1990 Iroc-Z
The general rule is that a newer engine in an older car is legal, while retro fitting an older engine into a newer car is not. But - emissions guys can rarely (RARELY) detect this. It is just not what is being looked for.
Car: too many ...
Car: 1990 GTA
I don't what your smog regs are but generally speaking as long as you have all emissions equipment intact for the engine(or car which ever is newer) your probably okay. Your best bet is to ask a smog referee for the exact regs and requirements.
Sanjay
08-12-2015 03:41 PM
