MAF to MAP Pinning Question
I have read how to convert from MAF to MAP and bought the parts but my question is when I look at my 165 ECM I see the labels A1, B1,….. excreta just like the wire conversion table says but when I look at the 730 ECM and wires I don’t see BA11, GE9…. Excreta. It just has the connectors labeled the same as the 165 ECM. This is the table I am referring to (http://www.eecis.udel.edu/~davis/z28/ECMs/86to92.txt) Which I got from the ECM upgrade artical on this boards technical articles. What am I missing.
Any help would be appreciated
Thanks Scott
Thanks Scott
Car: 1986 Irocz
Axle/Gears: 3.25:1
Originally posted by ski_dwn_it
It might not be any business of mine, but what is making you switch over to SD? Just curious.
Sorry for the non-tech post but I could just sense the planets going out of alignment again.
sorry.
