Throttle position
Car: 1987 Trans am
Throttle position
i don't know where to post this. I can't find anything on how to adjust the throttle position sensor. Can someone help me with this or atleast point me to the right post.
Car: 89 IrocZ
Engine: L98-ish
There's a "How to" on the main page in the tech area...tech article or something like that.
There's also about 3 or 4 post's on this page your on now.
Then there's the cool little search button too. Try "TPS Adjustment" then "TPS".
You'll be flooded with responses.
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
Here ya go... This and more tech articles can be found on the main page. https://www.thirdgen.org/newdesign/tech/tpimod2.shtml
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
When checking with volt ohm meter, why can't U just poke the wires coming out of the connecter with the sharp probes, with it still connected?
