87 Firebird Carb To TPI Question
Old 08-31-2003 | 08:27 PM
NHRAK188's Avatar
I am looking to switch my 87 Firebird From Carb. to TPI,I have a wiring harness from an 89 TPI Car which I think used a MAP setup.I would like to know if an 89 wiring harness and ECM would work in an 87 car.If so does anyone have any ECM part numbers that I could use.
Any info would be helpfull,
Thanks...
Old 08-31-2003 | 10:00 PM
robert1's Avatar
Yes, it should work. As far as I know, the change was in 1990, when it went to a speed density system.
Old 09-01-2003 | 08:19 AM
NHRAK188's Avatar
What year did they switch from MAF to MAP Sensor?
Old 09-01-2003 | 09:33 AM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
1990
Old 09-01-2003 | 11:21 AM
NHRAK188's Avatar
Thanks for the replies..Anyone have any ECM #'s that I can look for..
Old 09-02-2003 | 03:18 PM
slytpi's Avatar
Car: 91 RS Camaro
Engine: 335 Stroker
Transmission: TH700R4
The ECM # that will work for 86-89 5.0 and 5.7 is GM p/n 88999194. This is the new GM part number. The old GM p/n is 16198259. This is only the ECM, no prom. I'm positive these are right, i work at a GM dealership, and I just looked them up
Vinnie
theshackle
03-05-2017 06:37 PM
ASE doc
Alternative Port EFI Intakes
08-25-2015 09:14 AM
86IROC112
08-17-2015 02:00 PM
redmaroz
08-16-2015 11:40 PM
Sanjay
08-12-2015 03:41 PM
Quick Reply: 87 Firebird Carb To TPI Question
