112 mixed w/93 oct. ???
Old 08-30-2003 | 03:17 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Can you mix 112 gas or a relative octane rating on a TPI without doing any damage to the sensors, valves, and etc.
This DOES NOT apply to emission legal TPI's.
iex. Cat. Convertors and EGR.
Old 08-30-2003 | 06:14 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Well, assuming the 112 is unleaded if you mix it with 93 you're basically creating (112+93)/2 octane or 102.5 octane rating with the formula you can look at on any gas pump. All it is going to do is prevent detonation, so it's not going to harm sensors in the least. If it's leaded thats different, and it can damage sensors - it will absolutley destroy an o2 sensor. May I ask why you are going to do this?
Old 08-30-2003 | 06:27 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
i was just curious. Would it make any difference though? Other than taking away detonation?
Old 08-30-2003 | 06:55 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
It may not be as simple as the math earlier indicated.
IIRC, years ago I read an article in some rag that running 1/2 and 1/2 (or some combo) could actually increase the octane number..i/e the higher number would nicrease.
Dunno if it's my fading memory, or fact.
Old 09-03-2003 | 08:59 PM
ski_dwn_it's Avatar
Engine: 2 mice and a cat
The math above it not correct, well it could be if a 50/50 mixture was used.
Here is the correct way to calculate the octane.
assume:
Fuel 1 = 93 octane
fuel 1 gal = 3
Fuel 2 = 112 octane
fuel 2 gal = 5
New octane = (fuel 1 * fuel 1 gal/total gallons)+(fuel 2 * fuel 2 gal/total gallons)
New octane = (93*3/8)+(112*5/8) = 104.875 octane
With a 50/50 mixture the above equation would work out.
Hope this help you out. You want to run the min octane to suite your specs for best performance.
MrPackstin
10-25-2017 08:09 PM
Cam-aro
Camaros Wanted
11-12-2015 03:35 PM
darwinprice
17
10-11-2015 11:51 PM
HoosierinWA
10-07-2015 10:15 AM
rusty vango
09-29-2015 02:44 PM
Quick Reply: 112 mixed w/93 oct. ???
