Pro Topline heads w/ TPI & HSR?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 88 GTA
Engine: 355
Just wondering if the bolt patterns will match up to those heads. I have the heads now and have my stock TPI but probably getting a HSR. Will both of those fit without any modifications? IF they do need to be modified then what will I need to get and do? While Im at it....(Ive asked this in another post), but which of these intakes will work best with my setup? It is a 355 w/ 180cc Pro Topline heads and a ZZ4 cam. The stall is a 2000-2200. I think I will have a ton of torque with the heads and cam but I still want some topend power so should I port the TPI intake or go with a HSR? What do you guys think?
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
yes it will fit both heads. click the green banner to get other questions answered.
Car: 88 GTA
Engine: 355
Maybe you didnt understand my question or maybe you just wrote it wrong. Im wondering if the stock TPI and/or the HSR will fit on the Pro Topline heads. Could you clear your answer up and is there any modifications that need to be made to make it work?
Engine: 360 HSR
yep i see what i wrote. i meant to say yes the HSR will fit w/o modifications. depending on year of TPI 85-85 fits no prob. 87-92 will need to either get an edelbrock base or elongate the four center intake bolt holes to match the 90* angle. the 87-92 are 72* angle.
gixxer92
05-18-2017 11:20 AM
