IAC question
Old 08-26-2003 | 10:14 PM
conlinj's Avatar
IAC question
What effects would i see if I drove around with the iac unplugged?
Old 08-27-2003 | 11:01 AM
Ozzy88GTA's Avatar
Car: 1988 Trans Am GTA
Engine: 5.0 TPI
Transmission: TH700-R4
The engine will not hold a steady idle. When you go put the transmission in Drive it will drop like crazy. Even if you set the RPMs for when in Drive, when you turn on any accesories like headlights, AC, etc., the RPMs will drop too. My suggestion is don't do it.
Old 08-27-2003 | 12:10 PM
formularpm's Avatar
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
A better question is why would you want to do it?
Old 08-27-2003 | 12:34 PM
conlinj's Avatar
Actually i don't want to do it, I bought a new one from Ac Delco when i replaced my throttle body and it went bad a month later. I don't have the cash to get another. I've been driving with it out for 3 weeks now. Car drives fine no dips in the idle at all in or out of gear. Same thing with the accessories no drop. I'll be getting a new one soon but the car has been fine with it unplugged.
Old 08-27-2003 | 12:37 PM
conlinj's Avatar
The reason i asked the question is because recently I started getting a Code 13 and a Code 21. I set the tps to .54 volts with the car off but keyed to "on". Question about that as well, what should it read at idle with the car running, still .54 volts? I was wondering if having the iac unplugged could be realted to those codes
Old 08-27-2003 | 03:18 PM
formularpm's Avatar
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
Your code 21 is a TPS code, and yes the voltage should be the same with key on/engine off, and with the engine on. The code 13 I believe is an oxygen sensor lean code.
Old 08-28-2003 | 11:05 AM
conlinj's Avatar
ya it was definalty my tps, it showed 1.5 volts with it turned all the way down !!?? so i put in my spare on and it's all good. The computer was probably reading the tps voltage and enriching the mixture and causing the o2 to triger a lean code. It would go 3.75 volts at 1/4 throttle. I'm still going to put my new Heated o2 sensor in cause this one is probably the original.
Old 08-28-2003 | 08:43 PM
88TAJeff's Avatar
Car: 88 T/A
I hate the IAC. Nice trying to stop the car when in drive and idling at 1500 rpm until fully stopped. Then when fully stopped, feeling the car 'un-load' the toque converter, and idle at 400. So I beat it by hooking up a switch to the IAC. That way I don't miss my cold starts, and when it's warm, I can just switch it off and enjoy a much better ride.
bamaboy0323
09-03-2015 06:07 AM
86IROC112
08-21-2015 07:20 PM
86IROC112
08-21-2015 12:39 PM
redmaroz
08-16-2015 11:40 PM
bamaboy0323
08-15-2015 07:20 AM
Quick Reply: IAC question
